on 24-05-2022 02:05 PM
About a year ago switched from broadband with talktalk to faster fibre 150 again from talktalk, came bundled with an eero 6 router, loved the interface but range was dreadful, worse than the broadband.
Talktalks solution was to ditch the eero, connect the fibre ONT to the old broadband router and send us a janky old WiFi extender. We have lived with it for now, but want to go back to the eero or similar, for the interface and parental controls, and have the following options
Get a second eero router and set up a mesh to hopefully increase range
Can get Tenda Nova mw6 3 pack for less than the cost of 1 eero
Can get TP link deco m5 3 pack for a little more thannthe eero.
Can get netgear orbi (rbk352) 2 pack if I push the boat out.
Current speed next to router is 125mb/s
Would option 2 and 3 work with the gear I have? What would you do
Based in UK.
on 24-05-2022 02:49 PM
The problem with some of the cheaper Mesh options is that they use fixed WiFi channels & their configuration options are probably far less than the WiFi Extender that you have currently (assuming it is the TalkTalk WiFi extender). The first thing I would do is a WiFi channel scan of your area, as it may not be the product giving poor range, but WiFi interference in your area.
Slow speed, intermittent dropouts, breaks in the signal or no signal on some or all devices or no internet access might be caused by Wi-Fi interference from other local networks, which can also lead to a permanent reduction in speed. No ISP can be responsible for your local environment, this is mainly a by-product of the popularity of Wi-Fi.
The next stage involves sending out a guide to you to help you get me some important diagnostic results so that I can analyse them for you and recommend changes to your router configuration to solve them.
