the GUI on my dg8041 router will not respond
GrayCon
Message 10 of 10
My DG8041W hub is working fine . However. I can not access the GUI!
My internet is connected via a DG8041W hub and DZS  box to a Freedom fibre FTTH Talk talk network. It is providing a solid 500+Mbps ethernet speed and the WIFI gives up to 350 Mbps.
However it will not respond to  the normal 192.168.1.1. address - the link just times out
I have re-booted the hub with no effect . I would rather not have to do a factory reset as  I might loose my current settings and not be able to put them back.
Has any one any ideas.
9 REPLIES 9
Message 1 of 10
Thanks for the update 🙂
Message 2 of 10
This morning I carried out the Factory reset. It has cured the problem and as the GUI has come back I was able to reconnect  all attached equipment.
Still not sure why I had the problem but at least it is now cured. Thanks for the input.
Message 3 of 10
GrayCon
Message 4 of 10
Thanks I'll wait until Wednesday ,when, if thing do go badly,  it won't cause so many problems
I'll report back when I have done the reset to let you know how things went.
Message 5 of 10
It's hard to tell.  I'd try the reset and see what happens.
GrayCon
Message 6 of 10
Hi Karl
Thanks for the response. I had  feeling the the answer would involve a factory rest, I was just hoping that there would be something else.( I have use ccleaner to clear the cache and there are no popup blockers operating)
As my my connection to the network is good, I am nervous that a reset could cause the hub to fail leaving me with no Internet.
Do you have any experience of this problem ? do you think that this might be a symptom of an impending failure? or just a software glitch.
Message 7 of 10
If this is still happening from an ethernet connection, and any pop up blockers are disabled and browser cache has been cleared, then the only option left would be to pin / factory reset the router.  If still failing then we can replace the router.
Message 8 of 10
Thanks, but that is the way my main pc is connected and I  use that to control the hub.
addition info - both my ethernet connected pcs and my phone and tablet all time out when trying to connect to the hub GUI .
paulshent
Message 9 of 10
Try a direct ethernet cable connection to the router in question and see what results you get.
