track fault detected
jonny51
Message 8 of 8
my internet has been unstable for 3 weeks now and its got to the point where my router just keeps resetting every 5 minutes , the lights flash orange then back to white, also when im in game my ping is a lot higher than usual, i  did a line check and it came back with track fault, i have tried ALL of the trouble shooting but still have unstable connection.
help.
thanks
Jonathan Harriss
7 REPLIES 7
Message 1 of 8
Hi jonny51
Thank you, please let us know how you get on.
jonny51
Message 2 of 8
im now plugged into the test socket, will monitor for a while and update you guys. thanks
Jonathan Harriss
Message 3 of 8
Could you connect your router to your Test Socket and monitor to see if it's still unstable. If your connection is still unstable with your router connected to your test socket then the next step will be to arrange an engineer visit
jonny51
Message 4 of 8
the router is connected to the one on the left of the open reach mk4
Jonathan Harriss
Message 5 of 8
Hi jonny51
Thank you. I've completed a line test which has detected a potential fault towards the property and Openreach have requested that we arrange an engineer visit.
Is the router currently connected at the test socket?
jonny51
Message 6 of 8
done
Jonathan Harriss
Message 7 of 8
Hi jonny51
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
