turn off the remote wifi optimisation feature
larkinmgg1
Message 2 of 2
Every day when I return home from work my 5GHz wifi channel has been reset to channel 100. It is not set to auto, I am manually changing it to channels between 36 and 48 as I have an Amazon Fire Tablet that does not support 5GHz channels above 48.
Having read a couple of similar threads about the wifi channel changing by itself from one I have set it to deliberately in the routers admin UI, it appears I need to ask TalkTalk to turn off the remote wifi optimisation feature - Please could you disable this as I have no need for this feature, thanks!
Can you arrange for this please?  Thanks in advance!
1 REPLY 1
Message 1 of 2
optimisation is now off for you.
See if this helps.
