upgrade from fibre 65 to fibre 150
shamaela21
Message 4 of 4
If upgrade from fibre 65 to fibre 150 does the engineer need to come out and will I be charged anything more than the price plan listed on site? Thanks
3 REPLIES 3
Message 1 of 4
Hi shamaela21
I can see that martswain has provided some further information for you.
martswain
Message 2 of 4
@shamaela21
Both 150 services require an engineer visit.
The phone line version needs a modem to be fitted and your master socket may need upgrading to a g.fast version.
https://community.talktalk.co.uk/t5/Articles/Your-Fibre-150-250-installation/ta-p/2569618
Full FTTP (Future Fibre - Data Only) requires a cable to be brought into your home, drilling of a wall may be required and if the cable is underground, some earthworks too.
A termination point/modem will be fitted.
Your existing copper line will be disconnected and you will no longer have any phone service from TT.
https://community.talktalk.co.uk/t5/Articles/How-Future-Fibre-is-installed/ta-p/2555166
Both the services require power for both the modem and the TT router.
Chris-TalkTalk
Message 3 of 4
Hi shamaela21,
Are you uprading to G.Fast or our future fibre (FTTP data only)?
