week wifi signal
Paulm2727
Message 4 of 4
I have just switched from sky to talktalk on fiber 65 and my wifi signal is 20mps. can i use the sky extenders on talk talk router to boost the signal if so how do i  set it up.?
Do powerline adaptors provide the full speeds as with direct ethernet cable from the router?
Paulm.
3 REPLIES 3
Paulm2727
Message 1 of 4
I have tried the same set up which is very simple. connect to mains press the wps button for 2 seconds then press the wps button on router within 2 mins and its supposed to connect but mine i have power and wifi green light but the one that says connected no light at all? any ideas.
martswain
Message 2 of 4
Powerline adapters work at various speeds, read the spec of the model you have.
All recent versions have throughput speeds well in excess of the maximum 80 Mbps incoming line speed on Fibre 65 so will not be a limiting factor.
WiFi extenders do not care what router they are connected to, use the same setup you used on SKY.
Message 3 of 4
Hi Paulm2727
Please can you add your name and TalkTalk landline number to your Community Profile, we can then look into this further.
