wi-fi keeps dropping out
marbab
Message 3 of 3
Just wanted to report ongoing issues with loosing wifi signal few times a day. It bacomes a nightmare now when I'being dropped during conf calls etc. My devices dissconect and I have a crossed wi-fi icon with exclamation mark next to it, saying my wi-fi signal is poor and it will reconect me when wi-fi signal quality improves. And it comes bac after few mins. It happens on all devices: mobiles, laptops, android box etc. I tried everything: it is connected directly to the main socket, I moved my router to different places, I'm rebooting it  often.  Online line check says everything is ok ( few months ago I must admit it failed online test and some works has been done on the front of the house, but it didn't really helped /at least from my point of view/).
Could you please help?
Thank you very much
Message 1 of 3
Hi marbab
I think we should send a different make and model of router for testing, would you like me to arrange this?
Message 2 of 3
To enable me to help you, please can you specify the make/model of TalkTalk router that you are using?
