wifi dropping out
Mirandakma
Message 3 of 3
Hi. my wifi keeps dropping both on laptop and pc. also my phonecalls keep dropping when i am using wifi calling. not sure if i need a new router but I see that people have been having problems with the new one
Message 1 of 3
Hi Mirandakma
  • Name
  • Telephone number
  • Alternative contact number
Skynet_TX
Message 2 of 3
Hi @Mirandakma,
Do you know if the problem is with the router losing its connection to the internet (in which case a light on your router which is normally constantly lit will change colour or flash), or is it that you are losing Wi-Fi connection between your device(s) and your router (in which case the light(s) on the router will just carry on looking normal).
Do you have any ‘wired’ devices, do they also lose connection ?
What make / model of router do you have ?
