wifi extender
maggiehay
Message 21 of 21
I use a talktalk wifi extender because my house has thick walls and the wifi does not always reach all parts of the house.  Last night there was a red flashing light on the part with the antennae and it was not doing its job of extending my wifi. I have spent this morning trying to pair up the 2 units following the instructions on the web site, but despite numerous attempts I have had no luck.  I would be grateful for any suggestions?
20 REPLIES 20
Message 1 of 21
Glad to hear it's all working 🙂
Message 2 of 21
Hi Debbie. It arrived about an hour ago and it is now set up and working as it should. Thankyou for all your help.
Maggie
Message 3 of 21
Hi maggiehay
How are you getting on, have you received the replacement adapters?
Message 4 of 21
Thank you Karl
Message 5 of 21
Thank you for your help Keith. Much appreciated.
Message 6 of 21
A replacement set of adapters are on the way.
Message 7 of 21
Thanks for that information, I agree that these units are faulty & I will ask TalkTalk to replace them for you.
Message 8 of 21
Hi,  the units are in the same room in sockets about 2 feet apart and the powerline light is not on on the antenna part.  I don't think my electrical circuits can be a problem because the extender worked fine for 10 months. It was a replacement for an identical unit that stopped working in exactly the same way. I can only surmise that these units do not last for long which is a shame because when they work they are good.  Thankyou for trying anyway.
Maggie
Message 9 of 21
No worries Maggie.
If you put the two units in nearby power sockets close to the router, does the power line lights come on in each unit then?
Do you know if in their normal locations (I assume one downstairs & the other upstairs) if each unit is on different electrical rings circuits in your main electrical consumer unit (fuse or circuit breaker box)? The easiest way to tell that is to carefully open the front, so as you can see the fuses or circuit breakers & look for more than one fuse per ring labelled something like:-
Downstairs sockets
Upstairs sockets
If in doubt if you can take a photo of it & upload it I can advise.
Message 10 of 21
Hi Keith,
Thank you for replying and my apologies for the delay in my response. I've had a streaming cold.
The power line is on on both units. The unit attached to the router has the power light and ethernet light on.  The unit with the antennae has the mains power light and wireless light on. The powerline light is not on. I have tried numerous times pressing the buttons on both units as instructed but all to no avail. The new router is a talktalk wifi hub and to be fair most of the time I am now getting enough signal to most areas of the house without the extender, but last night when my television connection failed for a short time I was cursing the lack of extra help from the extender.
Sorry to have rambled on.
Maggie
Message 11 of 21
Hi Maggie,
Thanks for confirming. Did you also see the post from @KeithFrench below?
maggiehay
Message 12 of 21
Hello Michelle,
I have had these extenders for 10 months. They were a replacement sent tor a similar problem in December 2020.  Up until now they have connected fine.
Maggie
Message 13 of 21
Can I just confirm, how long have you had these extenders? Have they previously connected ok?
Message 14 of 21
Hi @maggiehay
Is the powerline lights on both units? It may just be that the WPS clone of your WiFi settings has failed. If so, please check that WPS is enabled in your router. What make/model of router do you have since @Debbie-TalkTalk replaced your HG633, then I can tell you how to check WPS is enabled. Worst case scenario is I can tell you how to manually configure the WiFi settings of the extender if the powerline lights are on.
maggiehay
Message 15 of 21
Hi Debbie,
Yes I have looked at the help page tried the reconection tips a number of times.
Maggie
Message 16 of 21
Hi Maggie
Can I just check, have you taken a look at this help page? Fix a problem with your Wi-Fi Extender Kit
maggiehay
Message 17 of 21
Hello Debbie,
Thank you for sending out the new router. It does seem to give better connection to the more inaccessible areas of my home and I have packed up the old router ready to return.  However I am still having no luck connecting the wifi extender. It looks as if the problem is with the extender rather than the router.
Maggie
Message 18 of 21
Hi Maggie
Debbie 🙂
maggiehay
Message 19 of 21
Thankyou Debbie. That sounds good.
Maggie
Message 20 of 21
Hi maggiehay
I can see that you are using a HG633 router. Would you like me to send a different router for testing to see how the connection compares?
