wifi hub
skygrowler
Insightful One
Message 67 of 67
i have had this wifi hub for a while now and thought it would settle down but i am still having problems with it . my wifi seems to disconnect frequently and when it does connect it take a long time to connect .
I am also finding that when i wake up my phone or laptop it quite often comes up with a warning that i have no internet connection and then a second or two later it connects .
i think i have asked this before but is there a setting that saves power and shuts down the connection ? if so could someone point me to it ?
66 REPLIES 66
Message 1 of 67
No thanks as i said it has taken up too much of our time . i will just have to accept that it is as good as it gets .
thanks for your time and effort
sg
Message 2 of 67
Hi skygrowler,
Ok, I can raise it without the specific examples if you would like our Network Team to take a look anyway to see if they can see any possible issue?
Message 3 of 67
I have not made notes of when it has been a problem because it is constantly a problem .
I think you and I have spent way too much time on this  So I will have to put up with it and see what I can do from my end
Thanks sg
Message 4 of 67
Hi skygrowler,
Ok thanks for confirming this. Would you like me to pass this over to our Network Team for further investigation? Do any other devices drop at the same time as the cctv? Do you have any recent dates and times when you know that the cctv has dropped and I can ask our Network Team to take a look.
Message 5 of 67
I have not rebooted for several days.it was the same with 635  As I have said I am pretty sure it started when I changed to fibre
I am not keen on cancelling the speed boost just yet as I have a concession which will be lost but I think that will be the next step as it seems to me that the cameras don't like the extra speed  .
Message 6 of 67
Hi skygrowler,
Apologies for the delay. I've run a test on the line which hasn't detected a fault, however I can see a few re-connections on the line. Just to confirm, have you recently rebooted/switched off the router?
Could I also just confirm, did the cctv issue also happen when the HG635 router was connected or only when using the wifi hub?
Message 7 of 67
I realise that you would rather blame my equipment than yours 😉 but I didn't have any problem before I changed to fibre   I think it is more likely to be a problem with the actual Internet connection than anything else
Message 8 of 67
Hi skygrowler
Have you tested this (laptop) recently since the firmware update? I'm just trying to determine if this is just affecting the CCTV or all devices using 2.4GHZ.
Message 9 of 67
yes i have one laptop that is 2.4 and i think that suffers the same problem.
Message 10 of 67
Hi skygrowler
Do any other devices using 2.4ghz channel also experience the same issue?
Message 11 of 67
No .
Message 12 of 67
Hi skygrowler
Are you able to connect them (CCTV) to the 5ghz channel?
Message 13 of 67
Yes it is
Message 14 of 67
Hi skygrowler
Is this still the same following the firmware update?
Message 15 of 67
I don't know if this is any help but my Cctv works better when I am away from home on mobile data. On WiFi they more often than not take ages to connect or just time out .
Message 16 of 67
Message 17 of 67
i certainly will ,LOL
Message 18 of 67
Hi skygrowler
I've now changed the firmware. Please can you retest and let us know how you get on?
Message 19 of 67
@Debbie-TalkTalk what happened ?
Message 20 of 67
Did it  nothing happened
