wifi hub
skygrowler
Insightful One
Message 67 of 67
i have had this wifi hub for a while now and thought it would settle down but i am still having problems with it . my wifi seems to disconnect frequently and when it does connect it take a long time to connect .
I am also finding that when i wake up my phone or laptop it quite often comes up with a warning that i have no internet connection and then a second or two later it connects .
i think i have asked this before but is there a setting that saves power and shuts down the connection ? if so could someone point me to it ?
66 REPLIES 66
Message 21 of 67
Hi skygrowler
Our Products Team have asked us to try firmware version 1400t again. Please can you factory reset the router and I can then update the firmware?
Message 22 of 67
version SG4K10002600t
Message 23 of 67
Hi skygrowler
Which firmware version is currently showing on your router?
Message 24 of 67
OK thanks
Message 25 of 67
Hi skygrowler
I've contacted our Products Team in regards to this and I will post back on this thread as soon as I receive further information.
Message 26 of 67
it seems to be a fault with the 2.4 channel because all of the wifi hubs have had a problem keeping my cctv online and they are all 2.4.
Message 27 of 67
again , not as far as i know because the only wired connection is an iMac that is not used very often.
Message 28 of 67
Hi skygrowler
Are you still experiencing drops over a wired connection?
Message 29 of 67
Not as far as I know but I have to say that I only have one laptop which is exclusively 2.4 ghz everything else is dual band
Message 30 of 67
Hi skygrowler
Has the same fault occurred on 2 different Wifi Hubs?
Message 31 of 67
ok @Debbie-TalkTalk  i have rebooted and it has come back on but i really don't want to be doing this with a brand new router .
from other posts i have read it seems this router is a failure , i think it's about time TT admitted it and started doing something about it .
Message 32 of 67
hi @Debbie-TalkTalk it appears that the 2.4 channel on my hub has stopped working . is that something you can check from your end ?
thanks sg
Message 33 of 67
Hi skygrowler
Message 34 of 67
Actually it seems to have settled down now  so I will give it a bit longer
Message 35 of 67
Hi skygrowler
I can raise the intermittent connection fault over to our Network Team, would you like me to arrange this?
If you remove the fibre speed boost then the sync speed would be 40mb.
Message 36 of 67
@Debbie-TalkTalk Hmm that didn't last long , my phone used 0.7mb overnight and cctv cameras are on and off randomly , i have tried everything and nothing seems to improve the connection.
i am giving up on this now. i can only conclude it is down to the fibre connection being of poor quality as i have tried 3 different wifi hubs and 3 other routers including one non TT supplied router .
if i remove the fibre boost what sort of speed can i expect as all i think i can do is to start downgrading because everything worked before i had fibre.
Message 37 of 67
Message 38 of 67
will do thanks @Debbie-TalkTalk
Message 39 of 67
Hi skygrowler
Please can you continue to monitor this and let us know how you get on.
Message 40 of 67
thanks @Debbie-TalkTalk so far things are looking better ,overnight my phone has used no data and my speed has increased and connection seems more stable .
i know it is early days but hopefully the new router has solved my problems .
just one thing and i know you are going to say " ooh i wouldn't do that " but i have found that i get better wifi coverage by placing the router face down on the floor in an upstairs room and it hasn't caught fire yet ! emoticon.joytears.title
