wifi range
amitg
Message 8 of 8
Hi, we upgraded to fibre 65 last year. Speed is good near the router, but wifi does not reach upstairs and the back of the house.
will a new router help or wifi extender?
Router is Huawei HG 633
7 REPLIES 7
Message 1 of 8
Hi amitg
Would you like me to send a different make and model of router for testing to see how the connection compares?
Message 2 of 8
You wouldn't need to specifically use one sold by TalkTalk, there are plenty of Wi-Fi range extenders and powerline Wi-Fi adaptors available elsewhere (on Amazon for example).
A powerline adaptor like this for example (I'm not specifically recommending this product, or saying it is the right one for you, it is just an example of the type of thing you could use). This has one unit that you plug in next to the router and connect to the router with an ethernet cable, you can then plug the other unit into any plug socket in your home that is on the same electrical mains circuit. This specific example one will then broadcast a Wi-Fi signal from that second unit, and also has an ethernet socket on the second unit, so you could connect something to it 'wired' if you wanted to as well.
You can also buy range extenders / repeaters, these are just a single socket that you plug in roughly half way between where your router is, and where you want to get the signal to, these just pick up the Wi-Fi signal from the router and rebroadcast it, hopefully allowing it to reach where you want to get the signal.
Message 3 of 8
Thanks for your reply. My router is kept downstairs connected to the main telephone socket . So I’m not sure I can move it upstairs as you suggest .
I want to try a WiFi extender but it’s not available in the accessories store . Should I wait or are there any alternate available elsewhere .
Message 4 of 8
Thanks for your reply . I feel I should try a WiFi extender to get good WiFi in our room upstairs. Unfortunately they are not available on the accessories store . Where and when would these be available?
Message 5 of 8
Hi amitg,
  • Name
  • Telephone number
  • Alternative contact number
Message 6 of 8
I have used the HG635, HG633 and the latest Huawei HUB (DG8041W)
All provided virtually identical WiFi signal strength throughout my home.
The latest routers that have beamforming may be slightly better, but as they are all limited as to their power output you cannot change the laws of physics regarding distance and attenuation through solid surfaces.
However, they all seem to radiate downwards better than upwards, therefore my router lives in a spare room upstairs.
Skynet_TX
Message 7 of 8
Hi @amitg,
The newer Wi-Fi Hubs do have better Wi-Fi range that the older routers. I've personally used the HG633, and both of the newer hubs (the Huawei and the Sagemcom) can get Wi-Fi to rooms in my home that the HG633 could not.
However it is hard to say if it will make a big enough difference for you, it really depends how far away from your router you are trying to get the signal. A Wi-Fi extender will likely give you a stronger signal in more distant areas of the house, but it may be that one of the newer hubs may give you an acceptable signal anyway.
The staff here won't be around now until Monday, but they should be able to respond to this post early next week to help.
