Speed
broken1
Newbie
Message 2 of 2
I am on full fibre 150, what speeds can I expect?
1 REPLY 1
Message 1 of 2
What speeds are you getting and on what devices?
If you log into your router you will see the speeds to the router. This is where your speed is registered to. It should be 150 download. Up upload should be around 20.
Wifi speeds are always less as there is a drop off from the router to wifi devices. Even wired devices often show less than the speed to the router.
