on 24-06-2022 03:19 PM
So, City Fibre installed the GPON a few days ago. They said I needed a new router, which duly arrived. What happens now? They also said I wouldn't need a landline - is that true? The Telephone point is on the opposite side of the house. How will I know when the service goes live?
on 14-07-2022 08:50 AM
Thanks for confirming and I'm sorry that it took some time to fully resolve this for you. I've just sending you a PM with a short survey.
on 14-07-2022 08:48 AM
Hi Michelle, the speeds are what I would expect from the package I have, so I'm happy with that. My house is an old turn of the century sandstone building, so I've had to get wifi boosters in some rooms. However, the connection seems much more stable than ADSL, and that was more important to me. Thanks again for your support.
on 14-07-2022 06:09 AM
No problem. Are the speeds ok?
on 13-07-2022 02:58 PM
Thank you Michelle.
on 13-07-2022 06:13 AM
I'm really glad to hear that this is now working for you. I'm also going to feed all this back.
on 12-07-2022 09:09 PM
So there you have it! It was as simple as updating my customer profile from ADSL to Fibre. No cable problems, no ONT problems, no City Link problems, no router problems, no modify the van problem, nothing to do with my comb generating static or any of the other spurious nonsense spouted in the past three weeks. It was TalkTalk's inability to talk talk to TalkTalk. I now have a working system.
on 12-07-2022 04:57 PM
Hi Michelle, I see that another customer suffering the same issues has had his problems resolved after a call from the FF team in Manchester. See message below. Can you please arrange for me to have a similar call?
Yay - I have a WAN IP address up through the ONT on laptop plugged direct
which is a change that's just happened as it wasn't working at 1pm today.
Sarah from faults team in Manchester rang me and has changed my profile and worked through my setup and I can confirm I'm getting a public IP allocated and that Sarah can now ping my laptop from her end."
on 12-07-2022 08:00 AM
Apologies, I am still trying to get this resolved for you and I'm still in contact with the FTTP managers about this.
on 11-07-2022 05:26 PM
Hi Michelle, I'm afraid this is getting beyond tolerable. TalkTalk obviously have a problem allocation WAN IP addresses. There are more and more customers on here having exactly the same issue. If I thought it would do any good I would write to the CEO and complain, not about your efforts, which I'm sure are sincere, but about the failure of the FF team to be able to provide a simple solution to an easily diagnosed problem. Prevaricating over imaginary hardware compatibility issues, deflecting expectations by alluding to fantasy "resets" and asking customers to wait 24/48hrs and try again, are all symptoms of a failing support system, and an institutionalized culture of deflection.City Fibre are no better. I think my next step will be to contact the Communications Ombudsman and see if that generates a more positive outcome.
on 11-07-2022 07:26 AM
I'm really sorry about this. I've re-escalated this now and will let you know as soon as I hear back. It's also possible that they may try and contact you directly.
on 10-07-2022 09:47 AM
And 48hrs later - :WAN DHCP client (1) failed.
So, no change, just like all the others on here facing the same issue.
on 08-07-2022 09:37 PM
Hi Michelle, same old I'm afraid :WAN DHCP client (1) failed
on 08-07-2022 01:31 PM
Thank you. I will check back in with you to confirm how you are getting on.
on 08-07-2022 01:29 PM
Hi Michelle, many thanks. It is both connected and switched on.
Pat
on 08-07-2022 01:23 PM
A configuration change has been made. This can take between a few and 24hrs to update. Please can you ensure that the TalkTalk router is connected and switched on please.
on 08-07-2022 10:01 AM
I don't have a escalation number but I have someone from a different team looking into this for me now so I'm hoping to know more early this afternoon and will post back then.
on 08-07-2022 09:42 AM
Ok. Can I have an escalation number please? And I also read that other facing the same problem have an incident number for City Fibre, could I have one of those, please?
on 07-07-2022 12:21 PM
Hi Nikonbhoy
Michelle has chased again for an update on this.
on 06-07-2022 11:44 AM
At least there is recognition that there is a fault - it has only taken two weeks ...
... we are trying to authenticate it using our access and the result keeps on showing us we are unable to authenticate due to an error and we are trying to reach out City Fibre desk for further help on having your service authenticated Pat. And we are still waiting for their feedback. If you don't mind please continue using your old connection to sustain internet on your side , because I know how important having a service working . As we are still trying to raise escalation from City Fibre , I just would like to let you know as well that we are keep on monitoring your line.
... we make sure to report a faulty issue on your line and notate this on your account for future reference. And so our system detect automatically for any fault issues and a proper action will be taken cared on your account.
For the meantime Pat, as mcuh as we love to request a City Fibre engineer to visit your premise, however, we may need to send an escalation and that will be done by our manager. As of the moment, we cannot give you a reference number nor exact details for an engineer's visit since this needs to be emailed first to City Fibre desk and as far as I know the access that we tried to use connecting to that department is under maintenance. And we are still figuring out how to gain access again.
For the meantime, I know how shameful it is to say this , however let's stick on using your old plan at the moment to sustain internet connection to your and your family as I know how significant it is while we are trying to resolve your upgraded plan.
on 05-07-2022 10:19 AM
Apologies, I've chased this earlier this morning.
