on 23-05-2022 10:36 AM
Every night without fail at around 10-11PM onwards our internet becomes pretty much unusable. Resetting the router does not help, sometimes when I wake up in the morning the speeds have dropped to 0.1 download speed.
Resetting the router every morning does fix this until the same time on the night again when it just becomes unusable, we never had this problem with BT so I'm not sure what is causing it.
Any help would be greatly appreciated, thank you.
on 23-05-2022 02:12 PM
I've ordered the router, it should be with you within a couple of days, please let us know how you get on
on 23-05-2022 02:07 PM
Yes please that would be great thank you.
on 23-05-2022 01:44 PM
I can sent one to test with, would you like me to arrange this?
on 23-05-2022 01:37 PM
I'm afraid I do not.
on 23-05-2022 01:32 PM
OK thanks. Do you have another router that you can test with?
on 23-05-2022 01:17 PM
Around that time every night yes, it doesn't always need a reset sometimes it is fine when I wake up but sometimes when I wake up and do a speed test it will give results of under 0.5mbps download so the router will need to be reset.
on 23-05-2022 01:13 PM
OK thanks, so just to confirm, it starts at between 10pm-11pm and it stays like that until your reset the router? So if you don't reset the router in the morning does it just stay like that for the rest of the day?
on 23-05-2022 11:32 AM
No the light stays blue on the router but the connection just becomes really bad, it's always at the same time every night in the evening around 10-11PM onward until the morning this happens. Streaming anything constant buffering and pausing, online gaming isn't possible either with the lag. Very strange.
on 23-05-2022 11:18 AM
Thanks for updating your profile
Line test is passing but I can see that there have been some disconnections. Have you noticed if the lights change on your router when he connection becomes unusable?
on 23-05-2022 10:47 AM
Hi, thanks for the reply.
I have added that information now.
Thank you.
on 23-05-2022 10:40 AM
Hi stromderwelt
Please can you add your name and TalkTalk landline number to your Community Profile, we can then take a look at this for you.
