EERO Router - Modem Mode?
arfurmix
Message 4 of 4
HI,
I'm thinking about moving over to the Fibre 150 package from Virgin and I see the router supplied will be an Eero. Can this be put into Modem mode like my Virgin router? I currently have my own setup behind the Virgin modem and it works well, i don't want to disrupt it as i work from home and VPN etc is very important.
Thanks,
3 REPLIES 3
djbdane
Message 1 of 4
Yes - you connect to the ONT with an ethernet cable.
Message 2 of 4
Ahhhh i see, so i'd connect to the supplied modem with a standard ethernet cable?
martswain
Message 3 of 4
The EERO is just a router.
With Future Fibre 150 a separate ONT/modem will be fitted and the EERO connects to that, so you can ditch the EERO and use your own router.
