on 27-01-2022 02:53 AM
I'm on Future Fibre 500, received an Eero Pro 6 with my contract but the wifi range is so poor...
I live in a small 2 bedroom flat, the Eero is in my bedroom in the corner of the flat where the wifi is being used the most. It works just fine in this room getting 400+ Mbps, but if I leave the room and walk just a few meters away into the kitchen the connection quickly drops to under 50 Mbps and in the front room right next to the kitchen it's pretty much non existant, barely pushing 10 Mbps download with upload speed test completely failing and connection dropping constantly.
I read about Total Home Wifi, but it seems to only be available to Openreach customers? I'm with CityFibre.
Is there anything TalkTalk can do about this? Do I have to pay for another Eero or can they provide me a second one for free?
on 29-01-2022 01:10 PM
Other than that @Macready1982, if you want to create your own thread & let me know the address of it, I can help you now.
29-01-2022 11:58 AM - edited 29-01-2022 12:00 PM
As above, @Macready1982, the first port of call for support is the Future Fibre team.
Forum staff are not on here at weekends.
on 29-01-2022 11:28 AM
I am having the same problem...220mbps over WiFi if you are directly next to the gateway eero..
10 yards away and you are down to 50mbps and that's fibre500 got in touch with the fibre team and they did nothing to help at all...i upgraded from 65 mb but I am not seeing any improvement since installation 3 days ago
on 27-01-2022 09:42 AM
The next stage involves sending out a guide to you to help you get me some important diagnostic results, so as I can analyse them for you and recommend changes to your router configuration to solve them.
on 27-01-2022 07:22 AM
I'm sorry to hear this. I'd recommend contacting the Future Fibre Team so they can look into this further for you. There is the option to Live Chat at the bottom of the page.
