on 02-06-2022 02:35 AM
I get 700 mbps near the eero pro 6 router. But the speed drops to 250 away from the room where the router is situated. And it’s pretty much same speed near eero nodes too . I have 2 eero pro 6 and 1 eero pro. Wondering if anybody has tested orbi mesh network . I expect consistent speeds between router and nodes. I guess that is achievable with orbi.
My package is 900
Answered! Go to Solution.
12-06-2022 01:17 AM - edited 12-06-2022 01:20 AM
Seems like the only way to get similar speeds between eero router and nodes is to have it hardwired with Ethernet cable.
I have hardwired the node and my current average speed is 700. Previously it was 200-245 average and 400 max.
on 05-06-2022 08:08 AM
Every home is unique. With a high in the room location there's less obstruction from furniture, fixtures and fittings and greater distance from potential sources of electrical interference.
The two down-sides to a high in the room location are:
If the high in the room location works best for you then that's perfect.
Like below to appreciate my help . . . Mark as solved Accept as Solution
on 05-06-2022 01:03 AM
You are right Gondola , the node eero is performing well mid way off the ground. But I still feel router needs to be even higher, at least in my case I found it’s performing better that way.
on 04-06-2022 11:03 PM
The recommended placement in terms of height in a room is in the open, mid way between floor and ceiling.
04-06-2022 10:43 PM - edited 04-06-2022 10:45 PM
I have elevated the position of the router eero and speed improved. This is the data from recent tests -
Room where router is situated 750-800 mbps
Adjacent rooms to the router 550-600 mbps
Room where the node is situated 350-400 mbps
Adjacent rooms to the node 275-300 mbps . The node is still just under a meter high off the ground . I feel that if I elevate the node the speeds of the node will also improve .
eero router is almost close to the ceiling now , it’s on the top of a cabinet.
on 02-06-2022 11:37 AM
Similar situation here. I have 3 eero pro 6, unless I am literally within less than 2 meters from the gateway eero, the speed drops considerably. I switched to Talktalk for the eeros, pretty disappointed in their performance (eero not talktalk)
