on 05-01-2022 06:53 PM
Hi , I wonder if anyone can help . So recently signed up to future fibre 500 and went live this week however I am only getting speeds of 96-110 both wireless via eero pro 6 and through a wired test ( ethernet to ont ) . I have tried live chat who seem to have limited knowledge of the product and supplied me with a contact number for the future fibre team but I am still unable to reach someone who can help me with this . Any advice or help from an OP would be great .
on 10-01-2022 06:38 AM
Hi Hulkster81
I'm glad to hear that this has been resolved, thanks for letting us know.
on 08-01-2022 09:42 PM
Glad you've got it sorted out
on 08-01-2022 09:04 PM
All sorted . Rang up the FF team and it was an issue there side . I think they had me on wrong package . Now receiving around 533 mb so very happy . Cheers for all replies .
on 07-01-2022 09:36 AM
Had the same issue with upload speeds.
initially the response from FF support was that upload speeds are not guaranteed and you get what you get.
after some back and forth a BT engineer was arranged and he plugged his own laptop into the ONT and was getting the same results.
an hour or two later and upload speed when from 20Mbs to 75Mbs.
I'm 99.9% sure these are not capacity issues but profile issues.
on 05-01-2022 08:48 PM
Make sure you call the future fibre team though. And not the standard suport. FF team should be able to get things resolved.
on 05-01-2022 08:45 PM
I'll see what they say tomorrow but I'm not holding out much hope after today's offering . Cheers for your advice 👍
on 05-01-2022 08:32 PM
This certainly looks like a service issue. Either the ONT at fault or more likely a provisioning fault by Cityfibre possibly at the FX. You need to ask support to raise a call via the portal for Cityfibre and get them to check it out. You can also ask them to call the service desk at CityFibre to follow the call up, to get an update.
on 05-01-2022 08:07 PM
Response time is around 9ms
on 05-01-2022 07:57 PM
Hi , that was a laptop connected directly to the ont
on 05-01-2022 07:51 PM
When connecting via ethernet to ONT is that direct to computer or patched into the eero. Also what's the latency showing as when running a speed test.
