on 25-04-2022 09:33 PM
I have had full fibre since February (transitioned from a service down the phone line). My contract ended in early April. On Friday I recontracted for 18 months. On Sunday morning at 6.30am my connection randomly stopped working and my router now just flashes orange.
I've been passed around various agents who think it is a fault with city fibre (who run the fibre service in our street), but this seems far too coincidental not to be linked to the new contract I took on Friday. Especially as in the 'My Account' section of the website there is no reference anywhere to the new deal I signed up to. In the meantime I am just waiting for city fibre to call when I am pretty sure they'll say it has nothing to do with them.
Any ideas?
on 27-04-2022 01:31 PM
No problem 🙂
on 27-04-2022 01:22 PM
Superb, thank you very much!
on 27-04-2022 01:18 PM
That's fine, I've ordered the router, it should be with you within a couple of days
on 27-04-2022 12:47 PM
Hi Chris I cannot find an order number but have added my account number. Hope this is okay.
on 27-04-2022 11:31 AM
Thanks but could you also please add your Future Fibre order number to the private notes section of you Community Profile
on 27-04-2022 11:07 AM
All done, thanks Chris.
on 27-04-2022 11:03 AM
OK, can you please update your community profile to include your:
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 27-04-2022 10:54 AM
Yes please that would be fantastic.
on 27-04-2022 10:28 AM
OK thanks. Would you like me to arrange to send another router to test with?
on 27-04-2022 10:09 AM
Yes, I've done a couple of resets - leaving it off unplugged for 15 mins and then using a paper clip for the hard factory reset, neither have worked unfortunately. I also cannot connect to the router to look at the settings as it won't generate a wifi network.
on 27-04-2022 09:09 AM
OK thanks. have you tried resetting it to factory defaults. if not then it's worth a try?
on 27-04-2022 08:43 AM
It's this one:
TalkTalk Wi-Fi Hub – Enjoy a Fast, Strong, Reliable Wi-Fi Connection in Your Home https://smile.amazon.co.uk/dp/B07D6MVZJ4/ref=cm_sw_r_apan_i_RMM42MEZTE5C6F0N71CY?_encoding=UTF8&psc=...
on 27-04-2022 08:23 AM
Thanks for trying that, yes it does look as though it could be an issue with your router. Which router do you have?
on 27-04-2022 08:20 AM
Hi Chris, thanks for your response. I've only the one device with an ethernet socket (a smart TV), and didn't realise I could skip out the router but yes that is connected to the internet when I plug it directly into the ONT.
What does that suggest a problem with the router?
Thanks very much for your help!
on 27-04-2022 07:41 AM
Hi timgray85,
Are you able to test with a device connected directly to the ONT with an Ethernet cable bypassing the router?
on 26-04-2022 09:10 PM
P.s. 3 of the 4 lights are on on the ONT, the one that is not lit is labelled ethernet.
All cables etc. Have been checked and router has been reset.
on 26-04-2022 07:14 PM
Hi Michelle,
Yes I've been in contact with the fibre team. They have just raised an incident with city fibre (who I still haven't heard from, three days after first reporting the issue). I really can't help but think it has got something to do with the fact that I signed up to a new contract last Friday.
on 26-04-2022 08:17 AM
I'm sorry to hear this. Can I just confirm, have you been in contact with our Future Fibre Team directly? What lights are on the ONT?
