Poor Wifi Performance with Eero 6
AndyB321
Message 4 of 4
My experience with migrating to "Future Fibre" has not been a great one so far. First engineer doesn't turn up to complete the install, once rescheduled turns up and does a bad job (spliced cable incorrecly) resulting in no internet for 48.
And now migrated I'm finding the Wifi performance of the Eero 6 routers absolutely dire compared to the old TalkTalk Wifi Hub.
I've even purchased a second Eero 6 to extend coverage but still have dead spots and poor signal in certain parts of the house/garden.
Is this to be expected?
3 REPLIES 3
Message 1 of 4
Ok thanks for confirming. Have you also tried following all the steps in the eero app?
Message 2 of 4
Hi Michelle, yes I've been through all the above. Performance on wired devices or those wireless devices located close to the access points are fine, it just seems to be anything with a little bit of distance is dire with constant drop outs.
Just seems like the Eeros provide a much weaker wifi signal compared to the TalkTalk Hubs which I'm trying to confirm is to be expected?
Message 3 of 4
I'm sorry to hear this. Have you had a look at the below Help Guide?
Slow speeds on your eero network - TalkTalk Help & Support
