on 16-12-2021 11:24 PM
As a computer technician I'm familiar with various broadband problems and solutions, but am stuck in this particular case. One of my customers upgraded their TalkTalk broadband to Fibre 150 a few days ago, and while they're getting superb download speeds, upload has been consistently no more than around 0.8 Mbps. Fibre 150 is presumably FTTP, meaning they've got a brand new connection and Openreach modem, and I know they got a new router in the process. So I'm wondering where the fault might be, and what can be done. Multiple calls to TalkTalk have yielded various explanations but no solution.
on 20-12-2021 05:39 PM
Thank you for your reply, but we no longer need help. You can read my Trustpilot review for an explanation.
on 20-12-2021 08:07 AM
We'll then look into this further. Please do not post this information on this thread. Once you've updated your profile please post in your topic to confirm it's updated.
on 17-12-2021 09:15 PM
@medwds, use the camera icon or this to display a screenshot in your post;
on 17-12-2021 09:08 PM
Thank you for your concern, @ferguson. The product must be Fibre 150 over G.fast because SamKnows says the exchange in question doesn't have FTTP. I didn't know G.fast was used in the UK, and wish to thank @martswain for bringing this to my attention.
on 17-12-2021 08:54 PM
I've tried three times to reply, and each time it gets deleted instantly, though I can't see anything obviously spammy or otherwise prohibited in the text. So I'm going to resort to attaching it as an image.
Okay, maybe not — "The file type (.png) is not supported. Valid file types are: pdf, doc, ppt, docx, pptx, xlsx, psd, gz, zip, svg, .txt."
How strange — surely screenshots are one of the most likely things people would need to post. SVG and Photoshop formats are tempting but I think I'll settle for plain text — let's see if this uploads… No, it literally says "The file type (.txt) is not supported" and then goes on to list .txt as one of the valid types. I despair.
on 17-12-2021 08:46 PM
That is probably why the spam filter intercepted it. Can you summarise the issue in a few lines, especially which product it is? This community is customer based, it will be impossible to advise other than in general terms if the user is not registered here directly.
on 17-12-2021 08:34 PM
This is a test. I posted a detailed reply a few moments ago, but it was marked as spam. Luckily I've kept a copy because it took about an hour to write and edit!
17-12-2021 06:55 AM - edited 17-12-2021 06:56 AM
@medwds never presume, there are TWO Fibre 150 products.
One is g.fast FTTC over a phone line, the other full FTTP (Future Fibre)
Both require a standalone modem as TT modem/routers do not work with g.fast
