VOIP - phone line says 'Device Not Registered' - Just me?
themanc
Message 10 of 10
Sun 13th May we noticed we could not receive or make phone calls via our VOIP setup despite it working for the last 4 months
After 4 phone calls to TalkTalk and a new router sent we still get the 'Device Not Registered' message when trying to call out.
I have been promised a call back from the Operations team to try and resolve it, but I am wondering if I am alone with this issue or if its more frequent than talktalk make out.
I even tried another phone plugged in, same issue
Incidentally if I try to even call my home phone now I get a message saying I have dialled an incorrect number
My fear is that somehow my phone line has been removed and I might lose the number I have had for 17 years. Its rarely used, but its there as an emergency contact for parents etc to ring us who dont like ringing mobiles
Alternatively, if anyone can provide any solutions to try I am all ears.
Tried the reset stuff etc. I can't test the wall port for the old copper line as naturally its been disable since I went to VOIP
9 REPLIES 9
Message 1 of 10
OK thanks. I can't think of anything else that we can try but I've taken a look at your account and it looks as though the callback is booked for tomorrow morning so hopefully they'll be able to help further then.
themanc
Message 2 of 10
apparently can take up to 5 days. I had to speak to complaints team as I don't find that acceptable. He is going to try and escalate internally to speed it up.
I have been reading online about the DEVICE NOT REGISTERED message I keep going and seem to think this might be the advice:-
It reads:-
Your phone adapter will say "Device Not Registered" if it is unable to contact our network to properly register with your account. The most common cause for this occurring is that your phone adapter is set up behind a router that hasn't been properly configured.
Whether that helps in any way I have no idea, sounds like it is an issue at talktalk end
Message 3 of 10
OK thanks for trying. When did the Operations team say that they will call you back?
themanc
Message 4 of 10
tried it previously, but tried again today. No change whatsoever
Message 5 of 10
Have you also tried powering the ONT down for 30 minutes?
themanc
Message 6 of 10
tried that for 30 minutes - Nothing, no difference whatsoever.
I honestly think that somehow the copper line has been disconnected as expected and TalkTalk have missed a step to keep my number on VOIP and I fear I now have lost the number forever
Trying to call the number says its no longer registered
Message 7 of 10
Hi themanc,
Could you try switching the router and digital voice adapter off for 30 minutes, then switch back on and retest
themanc
Message 8 of 10
Yup,
was working find for 4 months.
The brilliant idea by the support team was to send me a new WiFi Hub2. Plugged the phone line directly into that instead as directed and absolutely no difference
Message 9 of 10
Can I just confirm, are you using an eero and the digital voice adapter or the Wifi Hub?
