on 07-04-2020 11:55 AM
If your a gamer and having ping issue’s, Try turning your router off for at least 30minutes then back on. Check that the snr upstream is around 5to7 if it is you should find things better, if it’s not, try factory resetting the router and hope it’s not as high as the 15 mark, because in my experience it’s impossible when as high as this, when my upstream was around 5to6 it was flawless.
