Has you speed decreased recently was getting 65mb then went down to 35m no clue why this how i fix?
Sightseer
They gave me advice they said line was fine fair inuff change the router told them router works fine never had problem so my internet was still in a confusion checked all cable everything was fine . So the cure was to switch the router off for around 34min from plug not disconnect cables no need and it worked my internet came back up to 65mb please be aware you can only switch a router off 2 times a day any more will screw up the internet at the openreach side its called dlm will kick in you dont want that so 1ns power off 30-34min worked a charm . You can reapeat the process router off 24 hours after due to dml as i explained i hope it helped someone (let me know please )
