Help "configuring" WAN with two TT HG633
1 REPLY 1
marcofm
Please help me to configure two TT HG633.  I am a real rookie.  A step-by-step will be very much appreciated.  I know what I want but not entirely sure HOW... My intended configuration below:
Thank you.
Always looking for a smart answer...
A picture paints a thousand words. I take it that you are trying to connect the two routers via their WiFi? This is impossible because they are APs (access points), one would need to be a WiFi client.
The only way to do this is via an Ethernet connection (ideally LAN 1 on one router to LAN 1 on the other, or connect the two LAN ports via Powerline Ethernet adapters.
