Is anybody using Google Wifi succesfully ?
Whilst I have not had any experience of Google WiFi, I don't seem to remember any problems with a router in a blog I read, by a TalkTalk guy who reviewed this & other mesh systems. I don't know if you will have access to read this, but it is located at:-
https://community.talktalk.co.uk/t5/Our-Blog/WiFi-Mesh-everything-you-need-to-know-amp-more/ba-p/213...
Lada_Dave
Thanks, I have read that post and it simply stops at saying you could double Nat problems and doesn’t give any detail in how to overcome them.
Lada_Evans
charlesb224
Wise Owl
https://support.google.com/wifi/answer/6240987?hl=en-GB
Funnily enough, Google recommend enabling bridge mode in your isp''s router
charlesb224
Wise Owl
Which model talktalk router do you actually have?
Lada_Dave
Yeah I have read that.
I have the D Link DSL 3782 and the pic are the options in the google Wifi app.
Lada_Evans
charlesb224
Wise Owl
I presume you've set the WAN tab to DHCP
charlesb224
Wise Owl
And. I have ask. You do have an ethernet eable between the LAN port on the back of the talk talk router and the WAN port of the Google WiFi?
Lada_Dave
Lada_Evans
Lada_Dave
Correct, port 1 to the Ethernet port on the google wifi
Lada_Evans
charlesb224
Wise Owl
192.168.1.2 address tells me that you didn't disable the Talktalk router dhcp server
charlesb224
Wise Owl
Or, if you did, you need to reboot the google wifi
Lada_Dave
ok so set the router to bridge and disable the dhcp then then rest the google Wi-Fi and this should work??
Lada_Evans
Lada_Dave
Wow so I have enabled bridge mode and disabled dhcp in the router settings. Rebooted the router and my google Wi-Fi and it appears to all be working now!
How do do I know reaches the router settings as 192.168.1.1 doesn’t seem to load?
Also so how do I check if I have a double bat situation?
Thank you again OWL!!
Lada_Evans
Lada_Dave
This is what the app now shows:
Lada_Evans
charlesb224
Wise Owl
If you want to reconnect to the TalkTalk Router - if you kept wireless on, then you can connect to the WiFi using any device : BUT crucially, you must specify a Static IP address:
IP: 192.168.1.x (x = any number between 3 and 254)
Subnet: 255.255.255.0
Gateway: 192.168.1.1
Only then can you connect to the TalkTalk Router and reach the settings page.  You can also do this via a ethernet cable, again you must set a static address.
Lada_Dave
That’s awesome, thank you so much for your help.
It it is greatly appreciated!!!
Dave
Lada_Evans
pweare
Just a warning about this....
I've been on the phone for ages with TalkTalk after my internet decided to stop working last week. It failed to get an external IP address for some reason.  Must be something at TalkTalk end, as after all the frustration of long calls it started working again with a brand new external IP address.
Now the issue with TalkTalk Support is that they keep saying that you have to use a TalkTalk router or they wont support you.  I've had a BT OpenReach modem connected to my Google Wifi for over a year now and no problem, working sweet!
But as soon as something goes wrong, TalkTalk say you have to use the TalkTalk router to connect or they won't provide any support.
We keep going round in circles..them saying it's my router, me saying it's at their end. They just keep saying 'well send you a new router and try that'.  Its the standard answer.
Has anyone managed to get round talking to TalkTalk support and getting them to understand not everyone wants to use TalkTalk Huawei routers. Well, lets see what happens when Huawei get banned just like they have in the states!  Good luck with that TalkTalk!
Anyway, rant over. Just a warning that the support you get when not connecting a TalkTalk product to the network is dire.
btw...i love my Google WiFi - it's like a breath of fresh air compared to all these free routers they keep sending me.
alexcosta
talktalk support is useless and not prepared to deal with more advanced users.
I have managed to configure Google wifi today using my HG633. I never used the talktalk router for wifi and it was previously connected to an airport extreme (double nat) but it was fine.
When I connected my google wifi to the router the double nat cause problems on google wifi and it worked for less than a day and started to display the red light on 2 devices. Looking on resons for the issue Google mentions that it can be caused by double nat.
I then changed the HG633 to bridge mode with the below instruction found in this forum (thanks to @beatledud and now all is working fine and super fast.
So - to all those wanting to Bridge the superrouter to their existing router.  Do the following
1. Set the PTM connection mode to BRIDGED
2. Disable TR069
3. Disable DHCP in the LAN
4. (Optional) Disable Wireless
then on your router.
Set WAN connection to DHCP/Automatic IP
