Multi room tv.
paultf1
Hello All.
Can anyone explain to me what is involved installing multi tv.
I have two plus recorder boxes and a non recorder box. I have read that you need an engineer visit, so how is it all connected if I wanted to do it my self.
I have WiFi connectors to be able to connect to the boxes.
1. Do you connect the boxes with loop out to one airial?
2. Can you use two plus boxes or is it one of each?
3. Can you recieve the boost channels at the same time and record if using to plus boxes.
4. Do you have to go into settings to set up the boxes.
Any advice would be most welcome.
Thank you.
Paul.
