Plume: wifi internet speed tests compared
6 REPLIES 6
josepv
Could anyone post up their experience with the speeds they get at the router, wired – 75Mbps down and 18 up, in my case – and the speeds shown on your mobile device (iPhone etc.) using the fast.com or speedtest apps.
Are you able to get above 70Mbps over wifi close to a pod? Or is it between 60-66Mbps?
Divsec
Hi Josepv, most of my tests are wireless. My sync rate is 73999 and I regularly see 69.1 both on my Sam knows box and anywhere in the house I test.
josepv
how many pods do you have? Are your internal walls solid brick?
Divsec
Hi Josepv 2 super pods and plaster board construction.
Are you having problems? Their help desk are very efficient.
josepv
Beta testing for them; wanted to gauge how people are finding them in UK homes. I've a 30s house, all brick internal wall construction 😞 not very wifi friendly. I need 5 pods to cover my home.
Thanks for your input.
Divsec
Have they offered you power pods yet?
josepv
I have the superpods
