Port forwarding on TalkTalk Wifi hub problems
3 REPLIES 3
MalcolmD1
I was previously a BT and plusnet customer. I have two web cameras which I had set up to be able to access both internally and externally. Port forwarding was setup on the BT Hub to achieve this and works correctly for external network access.
I have done my best to replicate this on the TalkTalk hub but with no success. I'm stumped.  I've attached screen shots of both the BT hub and TalkTalk hub config. As far as I can see, I've set them up the same. Does anyone have any ideas? Thanks.
MalcolmD1
Any chance anyone can help... please?
Malcolm
Sorry I have only just seen this, do you still need help?
MalcolmD1
Thanks, but I don’t need help anymore. I started another thread which did get noticed 🙂 You made some suggestions which led me to find the solution (I needed to change the gateway on each device to point to the new router’s gateway IP - it was different on the BT and Plusnet routers).
