Tr o69
5 REPLIES 5
 What should tr069 setting be on echo life 8041 WiFi hub box ticked or not?
J max,
Insightful One
If you want to allow remote updates and maintenance it should be ticked, if you don't want to then it should be unticked.
I assume then it allows tt to update the hub? Thanks
J max,
Insightful One
Only if it is a talktalk supplied router.
Yes it is the latest 8041.
J max,
Tried to switch on by ticking box and confimat bottom page it says processing when I go back it's cleared the box?
J max,
