WiFi hubs
sirguy
Hi I have Two Talktalk WiFi hubs and would like to connect them to improve the signal.What settings would I need to change in the hubs if I was using one as a slave(extender) I have followed some you tube examples but as yet no luck. Once I’ve changed the ip address in the slave I then cannot get back in to It have to reset it again. I think my problems with the IP address as these hubs have a range from 192.168.1.1 to 192.168.254 Any help would be great in what settings need to be. Thanks
Sir Guy
