Blocked number pin?
ANSWERED
jackieh2009
Insightful One
Hi Guys,
I have just started blocking scam/marketing numbers today.
Once you have completed the block the service says you can check your blocked numbers by entering your pin.
Either I have forgotten it or not set one up. How do I change or set one up please?
Jackie
Just A Cheshire Kid In Elegant Heels (2009 pairs in stock) © SD, 2009
Labrat
Problem Solver
I also get this and have absolutely no idea what my PIN is, or even if I ever had one. I would like all calls blocked from 01383 (Dunfermline). They're getting completely out of hand.
jackieh2009
Insightful One
Solution
Solved my query. Found a Help page. Default pin is 1234 for anyone with the same question:)
