Busy tone instead of dial tone
4 REPLIES 4
southym
When i try to make a call i get busy tone immediately instead of dial tone. Ringing the phone from my mobile also gets busy tone. There is only one phone in the house and its plugged into the test socket of the master via the normal phone/broadband splitter.
My broadband is ok (it did go down for about 10 mins this morning).
I've been on live chat but all they have done is booked a call for Thursday for which i have to be at home - is there anything i check at my end to speed up this process?
southym
Thanks for you reply Keith.
Phone line seems to be working now so panic over 🙂
Mark
OCE_Arne
Hi southym
I will look into this for you and get back to you.
OCE_Arne
Hi @southym
Line tests are not picking up any faults, Are you able to test using a different handset, connected direct to the test socket?
