Caller ID
25 REPLIES 25
Hi guys, after literally years of a fault-free service my caller ID has suddenly stopped working, handset just displays "External Call." I tried disabling the service in My Account, left it for a few hours, re-enabled it again, left it a few hours more, still not working. Could you look into this for me please?
Cheers,
F
OCE_Arne
Hi @ferguson
I will ask for a card reset to be carried out.
Usually takes a few hours.
Thanks Arne, will check back later.
OCE_Arne
Hi @OCE_Arne , still not working I'm afraid.
OCE_Arne
Ok, I'll send it to the network team. Probably going to need a Lift and Shift.
Thanks @OCE_Arne , but why would it suddenly fail after working fine for all these years?
OCE_Arne
No Idea, engineers are in and out of exchanges all the time,  its possible one of them has done something.
I wondered if it was some fat-fingered OR guy, hey-ho!
Fixed.  👍
I guess you can ask the network team to stand down now.
OCE_Arne
Sorry to bother you further, but it's broken again.  🙁
OCE_Arne
@ferguson, Sorry to read that, I'll start the process of removing and re-adding it
Ta, got the changes email saying it has been removed.
OCE_Arne
Hi @OCE_Arne nope, sorry, despite showing as active in My Account. Display just shows External Call.
OCE_Arne
OCE_Arne
Hi @ferguson looks like the reset wasn't ordered for last night, should get done tonight, Sorry for the delay.
No worries, thanks for the update.
