Home Phone
Caller display
Alwaysatsea
Message 3 of 3
In case it helps anyone.Caller display stopped working three weeks ago.
Conventional landline over copper to conventional wireless Panasonic phone.
Spent an hour and 5 on the chat with lots of fobbing off and delay from the operator.
So without any help form support. Tried turning it off on the portal and on again, turning off the phone base station and back on again.
nothing worked.
Read a blog where someone turned off the caller display in “my boosts”, left of off for 24 hours.
Turned it back on again 35 hours later and within 6 hours it was working again.
I hope this helps talk talk support,  support its users properly or any users frustrated by talk talk support to try and fix this themselves.
Message 1 of 3
Hi Alwaysatsea
Thanks for your feedback. If you do experience any further issues then please let us know.
Message 2 of 3
Thanks for that, it does work in some cases, but sadly not in others. It is generally recommended as the first thing to try.
