Hi there,
I'm new to TalkTalk & I was wondering if it's possible to block all mobile numbers being called from my landline?
Hi @Charlotte2592
If you go into https://myaccount.talktalk.co.uk/myservices/myservices/view
About halfway down the page there's a section called Bar Features
Within that area There's an option called Mobile Bar, which will Block calls to mobile numbers
Hope that helps
