Home Phone
Can't make outgoing calls on landline
llanfair
Message 14 of 14
Hi there,
We get a dial tone but cant' make outgoing calls from our TalkTalk landline. We can receive incoming calls and the broadband is fine.. We did recently have a problem with receiving calls which then corrected itself (I think this may have been due to a problem at the exchange) - outgoing calls weren't a problem then. Please can you help solve this problem? Thanks, Simon.
13 REPLIES 13
Message 1 of 14
Message 2 of 14
Thanks Debbie - that's fine. I will update you afterwards. Simon
Message 3 of 14
Hi Simon
Thanks for confirming your details.
I have booked the first available appointment - 19/10 AM (8am - 1pm)
Message 4 of 14
Hi Simon
Thanks for your reply
I'm just sending you a Private Message to confirm some details so we can arrange the engineer visit.
Message 5 of 14
Thank you for running the further test. Yes, please arrange the visit by an Openreach engineer. Thanks,
Simon
Message 6 of 14
Hi llanfair
Sorry for the delay.
The line test is still detecting the same fault towards the property.
If you have tested with a different phone at the test socket and are still experiencing the same fault then the next step will be to arrange an Openreach engineer visit.
Would you like me to arrange this visit?
Message 7 of 14
Sorry, I mean connected to the test socket, not master socket (the one under the faceplate). Are you able to run the further test now? Thanks, Simon
Message 8 of 14
Hi there, I have just connected the landline to the BT master socket. Thanks, Simon
Message 9 of 14
Hi llanfair
Please can you connect just the phone at the test socket so I can run one more line test?
Message 10 of 14
Hi Debbie,
No, there's no error message. You get the dial tone but after dialling the number there is no change to the tone. Thanks,
Simon
Message 11 of 14
Hi llanfair
Thank you. I've run a test on the line now which has detected a potential fault.
What happens when you try and call out? Do you receive an error message?
Message 12 of 14
Hi there,
I've now updated my profile with that information. Thanks,,
Simon
Message 13 of 14
  • Name
  • Telephone number
  • Alternative contact number
