I have tried to remove some of the 98 numbers on my approved list in My Account. The numbers appear, but when I go to a number and click on any of the three options viz: view details edit remove
the entire list is shaded grey and I cannot make any changes. Only by clicking again can I get the list back to normal. Any advice on what if anything I am doing wrong would be appreciated.
Solved! Jump to the Best Answer.
Hi @Pal353
You've got nothing wrong. There's a TalkTalk unresolved bug in the system. Here's the workaround fix.
After clicking on Edit and the background gets greyed out just tap the keyboard TAB key twice to bring focus on the Edit window. Then proceed as normal.
