Home Phone
Change to Boosts not registering with Talktalk
duwcaruchi
Message 6 of 6
I am new to using the "Community" - only my second post - but why can't I receive a simple answer from Talk Talk? When I press "update" it says it has registered but in fact it has not. When I log out and then log back in the changes I have requested have been disregarded and I'm back to square one! Please tell me what is going wrong.
5 REPLIES 5
Message 1 of 6
Hi duwcaruchi,
I've sent you a PM to confirm some details so that we can look into this further
duwcaruchi
Message 2 of 6
Hi  -- Suggestion did not work. I did mange to change broadband package on line without any problem whatsoever so I don't understand why the home telephone boost will not work?
Chris-TalkTalk
Message 3 of 6
Hi duwcaruchi,
How are you getting on, has ferguson's advice helped?
Message 4 of 6
@duwcaruchi Clear cookies and cache and make sure pop ups are enabled on your browser. see if that helps. You should get a confirmation option.
Gliwmaeden2
Message 5 of 6
Likely to be My Account malfunctioning,  @duwcaruchi - as you know, many people are having this problem.
Staff won't be back on here before Monday. Best not to waste too much time over it, but Chat may be able to select / deselect boosts for you tomorrow, after 9am.
There's a turquoise label on the link when they are open, and hours of availability are also listed on this page:
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
