on 12-05-2022 09:21 AM
Please can anybody tell me the cost of calls to a UK registered mobile presently in Croatia.
I have the 24/7 inclusive call package with TalkTalk, would calls like this be included.
Any advice will be much appreciated.
Thank you, Rick
13-05-2022 03:47 PM - edited 13-05-2022 03:48 PM
If you call a UK mobile the cost to you will be the same no matter where it is, as far as TT are concerned you are still calling a UK mobile so it will be included in your boost.
Depending on what UK network the mobile that is on holiday in Croatia is registered to, roaming charges may be applicable and they could incur charges for receiving calls.
on 13-05-2022 03:17 PM
Hi Rick47
I think the charges will be from the carrier in Croatia unless you have the international calls boost which will reduce that cost.
You should be able to add it in My Account.
Hope that helps.
