For OCEs only - Poor quality calls in one direction
9 REPLIES 9
Hi Guys,
We have reported this before, but it has been intermittent & difficult to prove. Sometimes when we make a call the other end hears us OK, but what we hear is their voice breaking up badly. This is rather like a mobile call in a bad area. We had this twice today to two different numbers, once this morning & again at around 19:02 this evening. We have tried it with a cordless & a corded phone it makes no difference. In each case, we have originated the call, but I don't think that is anything to do with it.
When you remake the call, it is fine.
OCE_Arne
Hi KeithFrench
I'll run some tests and see if anything is picked up
I'll get back to you.
Hi @OCE_Arne
All of these calls seem to be to other numbers on our exchange. I don't profess to know how calls route within the same exchange, but I would guess that they use VoIP these days. The symptoms that we get is identical to a call going over a particular route where the QoS is either non-existent or wrongly configured, causing the RTP voice packets to break up, being held up by larger data packets.
OCE_Arne
Hi @KeithFrench
Hi Apologies Im not ignoring you at all, simply waiting for more advice from our network team
I have ran every line test we have at our disposal and nothing is picked up, so not really sure where to go.
Ill let you know when they reply.
Thanks @OCE_Arne for the update.
I have reported this about twice before & got nowhere. I don't believe it is anything to with either my line or phones nor the called number's line & equipment, because when you remake the call it is fine. I am convinced it is down to some bad route we pick up when the call routes to the destination (although on the same exchange).
OCE_Arne
Hi @OCE_Arne
If that was the case, surely the calls would be bad when they were remade straight afterwards?
OCE_Arne
We requested a card reset for Saturday afternoon,  Have you experienced the problem since Sunday?
Hi @OCE_Arne
Thanks for that, no we haven't had problems since then, but it may be a week or more before I can be sure due to its intermittent nature. I'll let you know.
