Home Phone
House Phone showing all callers as withheld??
Walden27
Message 8 of 8
Hi, our home phone as recently started showing all incoming calls as withheld numbers. Any way of sorting this out? Thank you
Walden27
7 REPLIES 7
Message 1 of 8
OK thanks. I've made a change so could you please retest and let us know if it's resolved the issue
Walden27
Message 2 of 8
No I don't, I'm guessing there's no answer or easy fix?
Walden27
Message 3 of 8
Hi Steve,
Do you have another handset that you can test with?
Walden27
Message 4 of 8
Test socket? It's connected to the main socket through a filter? Without that the router and phone play up
Steve
Walden27
Message 5 of 8
Hi Walden27
Have you tried connecting your phone directly at the test socket?
Walden27
Message 6 of 8
Hi, no if you call 1471 then it tells you the number, just says witheld on the handset
Thanks Steve
Walden27
Message 7 of 8
Can I just confirm, if you dial 1471 after you receive the call does it also advise that the number was withheld?
