Home Phone
House phone fault
Mags22
Message 3 of 3
On Friday I reported the fault after 1 hour 30minutes on line with little satisfaction .I don't have a dialing tone and this is the second time in 2weeks .I am frustrated with the service need a reply and some action
MARGARET TUOHEY
Arne-TalkTalk
Message 1 of 3
Hi Mags22
I will look into this for you and get back to you.
There will probably be an engineer arranged to go to the exchange in the next 48hours
Gondola
Message 2 of 3
Hi @Mags22
Please ensure your Community Profile Personal Information (Click here) includes your TalkTalk landline phone number and an alternate number (mobile recommended). Add, then scroll down and save changes. The TalkTalk Community support OCE will then be able to link to your TalkTalk service account and check what's happening.
If there's a fault on the incoming line then Openreach will be there to fix it.
GondolaVolunteer 2017-2021
 Like below to appreciate my help . . . Mark as solved + Accept as Solution
