How do I switch off Voicemail?
1 REPLY 1
jolomo4
how do I get rid of the landline voicemail altogether so no messages can be left, I want to use my own answer machine
Gondola
Hi @jolomo4
@jolomo4 wrote: ...how do I get rid of the landline voicemail altogether so no messages can be left, I want to use my own answer machine.
Sign in to your MyAccount and select My Services > Manage home phone Boosts and then untick the Voicemail option and select update and then confirm from the pop-up window.
You may have to enable pop-ups in your browser to see the pop-up window.
Gondola - Volunteer 2017-2021
