Home Phone
Inbound Calls Are Not Being Received
Charity17
Message 29 of 29
My telephone is not registering incoming calls.  I have just run a service check which identified a fault which the auto response said had fixed the problem.  This is not the case as when home number is dialled an immediate "hang up" is heard at the callers end and the house telephone does not ring.  Outgoing calls seem to be OK. TalkTalk have emailed to say service is working but to contact help service status, however, that does not seem to help as that was where I went in the first place.
Any advice on this matter?
28 REPLIES 28
Message 1 of 29
No Problem 🙂
I've also sent you a PM regarding our interaction.
Charity17
Message 2 of 29
Hi Karl
Yes Wednesday 6th July (PM) is okay.   Thanks for sorting this out.
Message 3 of 29
Earliest Appointment I have from Openreach is Wednesday 6th (PM).  I've booked this in, is this ok ?
Charity17
Message 4 of 29
Hi Karl
Looks like our messages have crossed.   I confirm that I accept the potential engineers charges.   As per my previous message an appointment for Tuesday 5th July PM would be preferred and I await your confirmation.
Kind regards
Message 5 of 29
Thanks for completing the Secure Verification. Please can you also confirm you accept the 'potential' engineer charges and let me know if there is a preferred day for the engineer to visit.
Message 6 of 29
We can never tell where a fault is located, this can only be truly identified by an engineer on site, but testing at the master socket directly reduces the risk of the fault being caused by something internal.
I'll drop you a PM with the info we require to proceed with an engineer booking.
Charity17
Message 7 of 29
Yes please. I assume this means the fault is somewhere outside the house, up to our MasterSocket?
Message 8 of 29
Hi Charity17
Thanks for your reply. The same loop fault has been detected.
Would you like me to arrange an Openreach engineer visit?
Charity17
Message 9 of 29
OK will do that now
Message 10 of 29
Yes please if that would be ok for another 15 minutes?
Charity17
Message 11 of 29
No the faceplate was not removed.  What do you want me to do?
Message 12 of 29
I've re-run the line test again now which is still showing the loop fault. Was the faceplate also removed?
Message 13 of 29
Unfortunately not as we are a online team only. I've removed this from your post now, please do not post any personal information on the Community. I will start the line test at 10:20 and it will be ok to re-connect your equipment at 10:35.
Charity17
Message 14 of 29
Hi Michelle
OK I will unplug our equipment now.   Would it be possible for you to text me on REMOVED when the test has been done.
Many thanks
Message 15 of 29
Would it be possible to do this just so we can fully rule this out as the next step will be an engineer visit to the property. We would just need 20 minutes to run the test.
Charity17
Message 16 of 29
Not sure if you received my original response.  I have tried different handsets, including a non digital one plugged directly into the master socket with the same result. I have also tested using the inbuilt "test socket".  Do you still want me to unplug our equipment?
Message 17 of 29
I'm sorry to hear this. I've run a few tests on the line now which have detected a loop fault which can sometimes be caused by internal wiring or equipment connected to the line. Have you also tested with a different handset? Would it be possible to remove all equipment from the line for a short period so we can re-run the line test again please?
Gliwmaeden2
Message 18 of 29
Staff will pick this up during the week,  Monday to Friday, @Charity17.
It's best not to post further as this delays the thread from reaching staff in the automated queue. Wait till they reply.
CJT1980
Message 19 of 29
@Charity17
I think the fact you have posted here and gone through those steps and confirmed it's not an internal issue, one of the moderators or community star's will pick this up and get you some assistance.
Charity17
Message 20 of 29
Hi thanks for your reply.   I took the faceplate off and plugged the telephone into the test socket but got the same result, an immediate hang up.   I am at a loss what to do next as live chats never seem to have any outcome and every time I start a chat I just have to go through all the same questions.  Any suggestions wou,d be appreciated.
