Home Phone
Incoming calls - does not ring phone and goes dead
normsland
Message 10 of 10
Hello Team,
I am just wondering if I could have an update on the fault I raised last Monday 14th Feb. The problem is that my home phone no longer rings and cuts off almost immediately after trying to call it. I have run through the tests. TalkTalk have acknowledged that there is a problem with my line. One Wed 16th Feb, a BT OpenReach engineer has been to the Exchange and Street Cabinet but said he could see a problem with the line. However he could not fix it and another engineer would attend.
This is almost a week ago now. Please can I have an update on the status of my unringing phone line.
9 REPLIES 9
Message 1 of 10
Hi normsland
Thanks for confirming your details.
I have arranged the engineer visit for 28/02 AM (8am - 1pm) This was the first available appointment.
normsland
Message 2 of 10
Hi Debbie,
Replied please let us know if you need anything else. Thanks
Message 3 of 10
Hi normsland
I'm just sending you a Private Message to confirm some details so we can arrange an engineer visit.
normsland
Message 4 of 10
Hi Karl,
Yes I have unplugged everything. Taken the faceplate off. Plugged the brand new phone from Curry's tried, then my Panasonic DECT both directly in the Test socket with no microfilter still does not ring. The fault seems to be intermittent my parents tried calling twice this evening, the first time their BT line said "there was a problem please try again" then the second time the phone actually rang.
Please can you arrange a BT Openreach engineer again.
Thank you
Message 5 of 10
Can you just test the phone only with no microfilter, just so you are sure the microfilter is not at fault. Also, if you are sure the phone you are using to test is in good working order, and this still fails, then the next option would be to proceed with an engineer booking for you.
normsland
Message 6 of 10
Hi Debbie,
Yes we have removed the front cover of the master socket and plugged the phone via micro filter in to the BT test socket and the problem still exists.
Please let me know if you need any further information. Thanks
Message 7 of 10
Hi normsland
Thanks for confirming this. One last question, is the phone at the test socket, with the face plate removed?
normsland
Message 8 of 10
HI Chris,
Yes we have tried a brand new telephone that we bought from Curry's last week the problem still exists. I have unplugged everything  and plugged the phone via microfilter directly in to the Master Socket. Therefore there is no router involved. This is a phone line problem not a broadband issue.
Chris-TalkTalk
Message 9 of 10
Hi normsland,
It looks as though the initial fault was cleared but line test is now showing a loop fault. Have you tested with a different telephone? Do you experience the same issue with the router disconnected?
