Home Phone
Incoming landline problems
Graham Hunt
Message 20 of 20
Talktalk ref: CMP-191731
I have a problem with incoming calls ringing once and cutting off, also people have said they have rung and not got through. It started a month ago with a crackly line. I have replaced my phone with a new one two weeks ago with no difference. I have been on the Chat to two operatives who were obviously reading from a list, I asked to be put through to an engineer and was told this was not possible. I was given a telephone number which turned out to be for mobile phones and would cost me 9 pence a minute going by the dial code.
I have received one text message on 01/12/2021 saying my complaint has been logged and nothing more since. I still have the problem and am deeply disappointed with the TalkTalk service so far. I am now thinking of changing provider back to BT so that I can get this problem fixed as it appears to be beyond TT engineers (If they ever exist.).
19 REPLIES 19
Message 1 of 20
Hi Graham,
Thanks for answering the security questions, I've sent you a PM requesting a little more information
Message 2 of 20
Yes I would like to arrange an engineer to call, most days are convenient, PM is best. The engineer charges are acceptable.
Message 3 of 20
OK Graham, I've run the test and it's still showing a potential loop fault. The next step will be to arrange an engineer visit, if you'd like us to do this can you confirm:
I've sent you a PM to confirm some other details
Message 4 of 20
OK thanks, I'll run the test now
Message 5 of 20
Okay, will do, will take off the cover in 1 minute, don't know how long to wait for though , will log back in in 30 minutes.
Message 6 of 20
OK thanks. The line test is picking up a potential loop fault which is usually caused by equipment/wiring in the customer home so could you remove the master socket faceplate leaving telephone and router disconnected and let me know when you've done this, I'll then run another line test to see if we get the same result
Message 7 of 20
NTE 5 as already stated, twice. I don't think this conversation is going in the right direction, I have already given the log number in my first posting, Talktalk ref: CMP-191731, other than someone actually fixing the problem, I don't want any other questions. There is a fault and I want it fixing please.
Message 8 of 20
Hi Graham,
As ferguson has asked, could you just let me know which type of master socket you have from those shown in Your guide to main sockets
Message 9 of 20
Can you just identify what your master socket looks like from the pictures in the link Chris posted earlier?
Message 10 of 20
Previous message;
Hi Chris,
There are two sockets one for the phone, BT4500 with inbuilt answer machine which I have replaced with a new unit two weeks ago and a socket for the TalkTalk wifi modem. There is an additional call display unit with the phone but I removed to check incoming calls and it made no difference, it is now connected again. I had the main NTE5 socket and internal copper wires replaced some years back on TalkTalks advice for another problem that we had at that time.
Message 11 of 20
Apologies, probably me being a bit thick but I can't see a reference in your first post to the type of master socket that you have. (I'm sorry but we do need to ask a few questions before arranging and engineer visit if required)
Message 12 of 20
Look at my first message please, I am not going to repeat myself again and again, I had this with the chat service and to be honest I am starting to lose confidence in you.
Message 13 of 20
OK thanks, which type of master socket do you have - Your guide to master sockets
Message 14 of 20
Hi Chris,
No I have two sockets, as per previous message, they are in different rooms, the phone and the router, they are both fitted with filters. The call display connects to the phone base but as I have already mentioned, I removed this and it made no difference so I replaced it so I can at least see who called.
Message 15 of 20
OK thanks Graham, so you have just one telephone socket (no extension sockets) with a the telephone connected to one port in the socket faceplate and the router connected to the dedicated broadband port in the faceplate?
Does the caller display unit connect directly to the telephone base unit?
Message 16 of 20
Hi Chris,
There are two sockets one for the phone, BT4500 with inbuilt answer machine which I have replaced with a new unit two ago and a socket for the TalkTalk wifi modem. There is an additional call display unit with the phone but I removed to check incoming calls and it made no difference, it is now connected again. I had the main NTE5 socket and internal copper wires replaced some years back on TalkTalks advice for another problem that we had at that time.
Message 17 of 20
Thanks for updating your profile
Line test is picking up a potential issue. How many telephone sockets do you have? Do you have anything connected to your telephone socket(s) in addition to your router and one telephone?
Graham Hunt
Message 18 of 20
Profile now updated.
Chris-TalkTalk
Message 19 of 20
Hi Graham,
  • Name
  • Telephone number
  • Alternative contact number
