Home Phone
Interference on home phone line
terry115
Message 16 of 16
Just moved into our new home and find awful swishing noise when trying to use our home phone line. Seems to be a regular problem on the community which gets resolved. Hope you can help here.  Terry
Terry
15 REPLIES 15
Message 1 of 16
Hi Terry,
I've booked the engineer for February 09 2021, AM (08:00-13:00) - please let us know how you get on
Message 2 of 16
Hi Terry,
I've sent you a PM
Message 3 of 16
Hi Terry
I've replied to your PM
Message 4 of 16
Hi Terry
Thanks for answering the security questions, I've sent you a PM requesting a little more information
Message 5 of 16
Yes, Chris, l'll pay any charges incurred. Availability is any day in the morning. Thanks Terry
Terry
Message 6 of 16
OK Terry,
If you'd like us to go ahead with the engineer visit can you confirm:
Message 7 of 16
Hello Chris
Thanks for your prompt reply. Yes, please book an engineer visit. I did see that earlier you said the line was clear, but the ex-BT engineer I had today is sure the fault is outside, so I hope the Open Reach engineer can sort it. If they report back they need to enter the property, it is empty so covid should not be a problem, but let's take one step at a time. Many thanks Terry
Terry
Message 8 of 16
Hi terry115,
Yes, if the noise is so bad that you can't use the phone at all then we can treat this as total loss of service. As the line test is passing we can only book this as an appointed visit to your home. The engineer may then decide on investigation that access to your home isn't required or is required but unsafe due to Covid restrictions.
If you'd like us to go ahead with the engineer visit please let us know and we'll confirm some details
Message 9 of 16
Hi Chris
We cannot use the phone due to the noise. In view of your reply I had a ex-bt engineer visit today to try to rectify the obvious fault. He confirmed the house circuit is ok. He also confirmed there is an external fault on the network back to the phone exchange. The fault is on the earth cable, also causing the ADSL to drop out intermittently. If we can't use the phone which he agreed then as far as I'm concerned that is a total loss of use, which is preventing us from moving into the property. As the fault is external there is no need for an engineer to enter our property. So I would appreciate if you would arrange a visit with Open Reach. We cannot continue like this for weeks or even longer. Thanks Terry
Terry
Chris-TalkTalk
Message 10 of 16
Hi terry115,
To investigate further we'll need to arrange an engineer visit but we can only arrange visits to the home at the moment for total loss of service, due to Covid restrictions. When the situation changes we'll be able to arrange a visit, apologies for any inconvenience
Message 11 of 16
Michelle, yes, there is a test socket which we tested with and without the microfilter, but interference is the same. Terry
Terry
Message 12 of 16
Hi terry,
I'm sorry for the delay. I've just re-read through your thread, can I confirm, does the master socket have a test socket behind the faceplate? If it does then is this were you tested just the phone with and without the microfilter connected?
Message 13 of 16
Hello Debbie
I have disconnected the router and used a different phone but the noise persists. Can you say what else to try. If it requires Openreach to visit, then can you arrange that. Thanks Terry
Terry
Message 14 of 16
Hi terry115
I've completed a line test which hasn't detected any faults - Line test is clear.
Have you tested with a corded handset directly at the test socket, with the router removed from the line?
Gliwmaeden2
Message 15 of 16
Staff will reply during business hours Monday-Friday, @terry115.
If you want to try to reach Talktalk over the weekend, try phoning 03451 720046. Saturday after 9am.
Chat can be reached any day after 9am. Scroll down on this page to find the link:
https://community.talktalk.co.uk/t5/Articles/Our-update-on-Coronavirus/ta-p/2468300
