Intermittent Caller Display
ANSWERED
13 REPLIES 13
John1949
We have had caller display ever since we have been with TalkTalk, about 9 years, but the service is now getting very intermittent.
Some calls still show the caller ID, but an increasing number are appearing as “External”. This is across the board, it makes no difference whether the call is from a mobile or landline, it even happens on calls from other TalkTalk users both locally and from other areas.
Any ideas?
Hi @John1949
Sorry that you are having problems.
The 1st step is always to remove caller display and then re-add the service, I will do that today,
If you can retest in 24 hours and let us know.
John1949
Hi Arne,
Definitely better but still some coming through as ‘external’ even though they are from known contacts. Should I monitor it for a week or so to give it a fair trial and update you again then?
John
Hi @John1949
Yes, keep an eye on it for a week or so and let us know how it goes.
Sarah1980
Hi Arne
After a reasonable result, where the majority of calls came through with an ID, it has now gradually deteriorated to a point where the majority of calls come through as 'external'. This is across the board, landline, mobile, local, national and other TT customers. Very frustrating!
I am also being prompted by TT to activate CallSafe on my line, but am afraid that with caller ID being so intermittent, I will end up not receiving calls that I want because they are not identified.
John1949
Hi Arne
For some reason my post of 2hrs ago has been attributed to newbie Sarah1980. It was actually from me as an update with the ongoing problem of caller display
Gondola
Hi @John1949 your posts are remerged.
Are you running both @John1949 and @Sarah1980 member sign-ins?
 Gondola - Offline : No posts or PM's
John1949
Yes, Sara1980 was visiting and used my computer and the accounts apear to have got mixed up. Sarah does not have a problem with the caller display on her line, the post is from me John1949
Sorry for the confusion
Solution
Hi John1949,
I'm sorry to hear this. Just to confirm, have you a look at the below Help Article which contains some advice on what to try if Caller Display is not working properly?
About Caller Display
John1949
@OCE_Michelle
Very helpful. Followed the advise in the article and it looks as though it may be my message machine that is causing, or at least contributing, to the problem. I have disconnected it and will monitor what happens over the next few weeks.
I will keep you updated.
Hi John,
Thanks for the update and please let us know if you need any assistance 🙂
John1949
@OCE_Michelle
Hi Michelle,
Caller display still working fine, so I guess it was my answer machine causing the problem.
Thanks for your help, much appreciated.
John
